Unity Connection VMO
Answered Question
May 26th, 2009
I am using CUCM Version 6.1.3.3000-1 and CUC Version 2.1.2.1000-380.
I have installed VMO7.0.1.FRA.msi for Outlook2003 on WinXP.
I can't use phone to listen to messages: "Unknown problems are preventing the completion of the call".
I tried using or not https.
The MediaMaster in ciscopca works well (CUC is able to call a Phone).
Correct Answer by Tana Franko about 7 years 11 months ago
Yes, unless CUCM and CUC are installed together as Cisco Unified Communications Manager Business Edition.
For supported versions of Cisco Unified CM and Cisco Unified CM Express, see the applicable document, depending on the integration type:
•SCCP Compatibility Matrix: Cisco Unity Connection, Cisco Unified Communications Manager, and Cisco Unified Communications Manager Express at http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html.
•SIP Trunk Compatibility Matrix: Cisco Unity Connection, Cisco Unified Communications Manager, and Cisco Unified Communications Manager Express at http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsiptrunkmtx.html.
Overall Rating: 5 (1 ratings)
Ginger Dillon Tue, 05/26/2009 - 07:22
  • Blue, 1500 points or more
Hi -
The first thing I would check is DCOM enabled on the PC workstation? From Start - Run - dcomcnfg. Expand Component Services. Expand Computers. Right-click My Computer and select Properties. Check the Default Properties tab. Make sure "Enable Distributed COM on this computer" is checked. Also, on the ViewMail for Outlook Options window - Outlook - Tools - ViewMail for Outlook. Server name should be fully qualified name of your Unity Connection server, including user's alias and password and subscriber's extension.
Ginger
guy.richard Wed, 05/27/2009 - 01:13
Hi and thank you for your answers.
Is it possible to upgrade CUC in 7.0.1 while the CUCM stays in 6.1.3 ?
Correct Answer
Tana Franko Wed, 05/27/2009 - 08:54
