TCL Hunt Group
May 26th, 2009
I am looking for a tcl script which can be used in SRST to provide a simple hunt group.
I would like to have a script which would be run when a specific dial-peer is matched and would then distribute the call to a range of extension numbers, preferable on broadcast, otherwise on a round-robin.
Do you have any examples of this?? I am currently using the alias command however that is limited to 50 entries. So looking to use a tcl script.
Overall Rating: 4 (1 ratings)
partheeban1 Wed, 06/03/2009 - 01:21
Hi Ian ,
I am also facing a same problem ..have you got any thoughts ???
Partheeban
paolo bevilacqua Fri, 06/05/2009 - 10:09
  • Hall of Fame,
    Founding Member
The solution is in the post above, have you read it ?
ian.ryder Fri, 06/05/2009 - 11:08
Thats not really a solution, its an alternative. I need a way of providing a hunt group (not using Alias or using CCME SRST)
paolo bevilacqua Fri, 06/05/2009 - 11:13
  • Hall of Fame,
    Founding Member
I believe that is a proper solution.
If you cannot adopt technology for whatever reason, that is not cisco's fault.
