Password Recovery on Unity Express CLI
Answered Question
May 26th, 2009
I can access Unity Express on the GUI, but I am unable to log into a CLI session on the service-module - GUI administrator login does not work.
How can I recover the CLI username/password?
Correct Answer by Brandon Buffin about 8 years 1 month ago
Are you running AAA on the router? Can you create a local user on the router and try to login with this username/password?
Brandon
Overall Rating: 4.5 (4 ratings)
Brandon Buffin Tue, 05/26/2009 - 07:53
  • Purple, 4500 points or more
Are you being asked for a username/password after "service-module service-enging 0/0 session"? If so, check the line for the CUE module. In your router config, along with "line vty 0 4", etc you will have something similar to "line 194". Is this line set to require a login? If so, remove the login command.
Hope this helps.
Brandon
clark-computers Wed, 05/27/2009 - 00:09
No login command, I'm afraid. Here's my line config:
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
access-class 23 in
transport input ssh
line vty 5 100
access-class 23 in
transport input ssh
Stu
Brandon Buffin Wed, 05/27/2009 - 04:38
Are you trying to get to the CUE module CLI from the router? Are you being prompted for username/password after "service-module service-enging 0/0 session"? Is it prompting for username/password or just password?
Brandon
clark-computers Wed, 05/27/2009 - 05:30
Yes I am, and I'm being prompted for both the username and the password.
Correct Answer
Brandon Buffin Wed, 05/27/2009 - 05:53
Brandon
Networkservices... Thu, 06/16/2016 - 16:43
I'm facing similar issue, however its Prompting just the Password.
Any help is highly appreciated.
Brandon Buffin Fri, 06/17/2016 - 05:20
Did you check your line configuration? For example:
line 194
login
transport preferred nonetransport input all
Do you see the "login" command as above? If so, remove this command using "no login"
Brandon
