H323 Channel selection order
Answered Question
May 26th, 2009
How do you specify channel selection order on a PRI with h323? I remember something like channel selection sequential, but cant remember where it is applied. thanks
Correct Answer by Paolo Bevilacqua about 7 years 10 months ago
You normally leave the default, if you can prove that it is not ok, then use isdn bchan-number-order under interface.
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Tue, 05/26/2009 - 07:45
  • Hall of Fame,
    Founding Member
