Sporadic SMTP Connection Drops ASA 5505
May 26th, 2009
My company is having some issues with receiving emails to our Mdaemon Email server. I had the Mdaemon techs take a look at what's going on and they say that our ASA5505 is dropping the connections. Now this is not happening all the time but sporadically it does. I need to get this fixed ASAP. I need some help. Our IOS version is 7.2(2). Probably a little dated.
Kureli Sankar Tue, 05/26/2009 - 09:07
  • Cisco Employee,
Pls. issue sh run policy-map
and see if you have inspect esmtp enabled. If so, pls. disable and see if the problem goes away.
rraymond731 Tue, 05/26/2009 - 09:17
It is enabled.. How do you disable it. I'm new with Cisco firewalls. Can this be disabled with users on the system? If this doesn't work, how to re-enable?
