cisco_lad2004 Tue, 05/26/2009 - 08:52
  • Gold, 750 points or more
RTR1(config-if)#ip load-sharing ?
per-destination Deterministic distribution
I think it depends on SUP. I am using SUP720 3BXL where per destination only is supported.
Sam
cisco_lad2004 Tue, 05/26/2009 - 09:00
Below command will give you a clear confirmation:
RTR1#show cef state (add capabilities in some platforms)
Sam
cisco_lad2004 Tue, 05/26/2009 - 11:11
No problems Pedro, glad I could help and learn in the process.
Please remember to rate or tick the solved box so other readers can save time when searching through.
Sam
