Unable to VPN connect to a ASA5505
dm7856255
Using the ASDM, I have setup access for a vpn. However,a connection cannot be established. Is there some setting that is not obvious using the vpn wizard
Richard Burts
David
Your post only says VPN and it would be helpful if you told us whether this was a site to site (LAN to LAN) VPN or a remote access VPN. There are different things that are important to each type and it would help to know which type as we try to think of what might be missing.
It might be even better if you would post the current config and let us look and see what we can find that might be the problem.
Rick
Rick
Probably I have similar problem.
On both sides I have ASA, through the wizadr i configure one side like VPN Remote server/concentrator, second on the Configuration-VPN panel like Ease VPN Remote.
IKE Phase I is OK, then connection failed.
What is wrong ?
Sincerelly
J.Kubenka
