routes from VRF to Global Table
May 26th, 2009
  • Gold, 750 points or more
According to the attachment, I am running OSPF between CE2 and PE2 and the rest of the switches bgp. mpls LDP enable between PE's. The routes in the VRF's on CE2 (VRF1/VRF2) i need to advertise in to the global routing table on PE2 so i can get those routes advertise in to BGP on PE2 so that PE1 and CE1 can see those routes. I don't want to enable trunking between CE2/PE2 to accomplish that or use route leaking.
Is there another way to get the vrf's routes on CE2 to PE2 BGP routing? Please note that PE2 is not aware of the VRF's..
rakesh.hegde Tue, 05/26/2009 - 12:25
You can loop interfaces using a cross over cable on the same router and put them in different vrfs/global routing table.At PE2 redistribute OSPF into BGP
HTH,
Rakesh
francisco_1 Tue, 05/26/2009 - 13:20
Rakesh,
thanks for your comment. can you please provide more info.
thanks
francico
