UCCX 7.0 BaseLineHolidayApp Script issue
May 26th, 2009
  • Silver, 250 points or more
I have this script working under UCCX 5.0 with no problem. However, when the script is created on a UCCX 7.0 system the problem comes in on the generated prompt for date entered. The creation of the prompt has not changed from UCCX 5.0. Does anyone know if UCCX 7.0 has changed the format in which a Month + Day + Year needs to be in. I've debug the script and all variables are getting written to the variables correctly. However, it is not respond back with the generated prompt. Once it gets to the "pholiday" variable and it is blank, but the script continues on to the confirmation prompt just fine.
Can someone confirm let me know if something has changed in how the system needs to read prompts to respond to date format?
kelvin.blair Wed, 06/03/2009 - 12:56
Figured out the issue. When upgrading to UCCX 7.0.1 no SR the issue occurs on all systems. However, if you apply SR2 the issue goes away. Apparently, this is a bug that is fixed in the SR2 patch for UCCX.
