CUCM 7 : Add persistent route
May 26th, 2009
In CUCM 7, is it possible to add persistent route. Has any tried this?
Overall Rating: 5 (2 ratings)
gogasca Fri, 05/29/2009 - 00:25
Yes via root access.
Checking the route table in Linux
netstat -rn
Adding and Removing a Network in Linux
route add -net gw
route del -net gw
This is not supported at all.
csshenoy80 Sat, 05/30/2009 - 12:30
root access is provided and accessed only by cisco tac. so is this supported or not?
Justin Pascal Sat, 06/06/2009 - 21:40
i know at work at tac, not supported, thats not the appropiate way to route packets in a network specifically a high availability server as CUCM, we can do it, but the best way to setup your network so traffic depending source uses different poath like route-maps. You can contact your local SE to push for a feature enhacenment to do that from regular cli.
I understand this is not big deal once we have the access, we do it in our machines everyday but we havent test it or we dont know how this affect your server at all.
gogasca Sat, 06/06/2009 - 21:48
Thanks Justin
Checking CLI for 7.x
We still dont have a command to add routes. This is in fact not supported, you can open a TAC case if its urgent, no problem, but as Justin explained you is not supported and not the best practice for a high availability server as CUCM.
Since we dont know what other behavior may affect the server performance.
