LMS 3.1 discovery
May 26th, 2009
I have 1100 devices that 'should' be discovered by my CiscoWorks server, but only 56 are. The rest show as 'device unreachable' in the discovery report. All of these devices were reachable by the 2.6 version of LMS.
Joe Clarke Tue, 05/26/2009 - 13:37
Make sure the community strings configured in Discovery are correct. If the devices are already in DCR, make sure you check the box in Discovery Settings to use the DCR devices as seed devices. If you do this, then the DCR credentials will be used instead of the Discovery credentials. This is analogous with how LMS 2.6 worked.
