Redirection question
May 26th, 2009
I am trying to setup for allowing outside callers to dial 0 to be redirected to reception extension when the user get voicemail. If anybody has any idea how to di it.
Thanks.
Overall Rating: 4 (1 ratings)
gogasca Tue, 05/26/2009 - 13:12
  • Green, 3000 points or more
If using Unity it should be in the caller input for subscribers, you send it to Operator
mrahman0302 Tue, 05/26/2009 - 13:30
I am using Unity 5. Do I have to select as alternate contact number and also configure on each subscriber for sending to operator extension?
