Use the variable for the IP address of IOS router
May 26th, 2009
Hi gurus!
I would appreciate if anyone can give me an advice for configuring the variable for the IP address of a particular router interface. All this is about
the router being a DHCP client which receives a new IP address every
now and then and using something like "$ETH0/0_IPADDR" instead of "ANY" in the access-list. As you know there's a way to use a variable with banner or hostname. Is there any way to do with the IP address?
Eugene
yjdabear Tue, 05/26/2009 - 16:44
  • Gold, 750 points or more
Assuming you don't want to settle for a limited "variable" through an ACL wildcard mask based on knowing the IP addr range assigned by DHCP, I think the EEM applet or script discussed in the following thread can conceivably be adapted to dynamically reconfigure the ACL accordingly:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&topicID=.ee71a02&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd2a971
I'm not sure what can serve as the trigger for EEM though, unless there's SNMP or syslog message generated when the int ip addr changes.
Joe Clarke Tue, 05/26/2009 - 19:16
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I actually did an EEM policy for this exact problem. What version of IOS are you using?
zheka_pefti Tue, 05/26/2009 - 22:11
about 80 routers run IOS 12.4(22T) and EEM is something new for me. Thanks a lot for refering to it. I will have to spend some time to get to know it.
Joe Clarke Tue, 05/26/2009 - 22:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Given that you have EEM 3.0, you could use the following programmatic applet:
event manager applet update-acl
event tag none
event tag syslog pattern "LINEPROTO-5-UPDOWN:.*Interface FastEthernet0/0.*changed state to up"
event tag timer timer watchdog time 86400
trigger occurs 1 delay 3
correlate event syslog or event none or event timer
action 010 cli command "enable"
action 020 cli command "show ip int brief | include FastEthernet0/0"
action 030 regexp "^FastEthernet0/0\s+([0-9\.]+)" "$_cli_result" ignore ipaddr
action 040 cli command "config t"
action 050 cli command "no access-list 113"
action 060 cli command "access-list 113 permit ip any host $ipaddr"
action 070 cli command "end"
action 080 syslog msg "New IP address is $ipaddr"
Here, you'll want to replace FastEthernet0/0 with your interface name. This policy will run every 24 hours, every time the device reloads, or every time you run the command "event manager run update-acl". You can, of course, adjust any of the tags and trigger correlation.
