BAT don't works
Answered Question
May 26th, 2009
Hi try updade lines on CUCM7
On Bulk Administration -> Phones -> Update Lines. I select the lines and select the change (partition), so I click on submit.
But on Job Scheduler, the task show like Pending, I activated the job, delete, re-created and nothing. This same thing with update Phones.
Is there any service that must be activate?
Peterson
Correct Answer by Jaime Valencia about 7 years 9 months ago
Make sure the Cisco Bulk Provisioning Service is running
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Wed, 05/27/2009 - 06:04
java
tafari.lima Wed, 06/24/2009 - 05:56
Hello Java,
I am trying to activate de Service, but when the page reloads the service still deactivated.
you know what can be? I am runing ccm 5.1(3)-1000
gshamlian Fri, 09/03/2010 - 09:18
I was having the same problem of it not getting past "Pending".  Tried deleting the job,
re-adding.  Stop Processing, then Start Processing.  Activate Selected Job.  Made sure the necessary services were activated, namely BPS, but also AXL and TAPS (as suggested by Cisco help site).  Finally, what worked was deactivating the BPS service, save, then reactivating it, save
