May 26th, 2009
I'm trying to configure NAC for Remote VPN users, I'm plaining to use the VGW mode.
I configured both E0 and E1 with the same IP address, I tried to verify connectivity to both interfaces using my PC with a cross cover cable. When I'm connected to E1 I can issue a ping, but when using E0 the ping doesn't pass.
Is this a normal behavior???
with this issue, the CAM can't connect to the CAS.
sbilgi Tue, 06/02/2009 - 13:20
If the CAM fails to import the CAS, make sure that connectivity is not an issue. You can attempt to ping the CAS from the CAM CLI when you log in as root. You can also attempt an SSH connection from the CAM to the CAS. Make sure that you have done the initial configuration in the CAS. You can use the service perfigo config command in order to initialize the CAS via its CLI.
