Is "nonegotiate" = do not negotiate speed and duplex or DTP?
Answered Question
May 26th, 2009
On a 3560 switchport below, my goal is to make this as "full duplex and speed 100". Since the connection is fiber, I don't see how I can get 100Mbps.
When I read the documentation, it is not clear whether "nonegotiate" is related to speed and auto or whether that is actually a way to stop DTP protocol on the interface thus avoiding trunking.
Am I right that I should do command "no negotiate"?
Gi0/26 myswitch connected trunk a-full a-1000 1000BaseLX SF P
myswitch#show run int g0/26
Building configuration...
Current configuration : 158 bytes
interface GigabitEthernet0/26
switchport trunk allowed vlan 2-5
switchport mode trunk
end
Correct Answer by Edison Ortiz about 7 years 11 months ago
Marlon,
You are referring to two different commands.
The speed 'nonegotiate' disables the link-negotiation protocol on the Gigabit Ethernet ports hence it speeds up the port opening process.
http://www.cisco.com/en/US/docs/ios/interface/command/reference/ir_s6.html#wp1017436
The switchport 'nonegotiate' disables the DTP process
http://www.cisco.com/en/US/docs/ios/interface/command/reference/ir_s7.html#wp1012629
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Tue, 05/26/2009 - 16:10
  • Hall of Fame,
    Founding Member
Marlon,
HTH,
__
Edison.
iyde Wed, 05/27/2009 - 00:00
  • Silver, 250 points or more
If you need 100 Mbps on fibre, then you could buy FastEthernet SFP for both ends of the connection.
This ensures that you'll stay at 100 Mbps :-)
