WLC526 - Guest Access with ASA
I am trying to configure WLC526 for guest access using a ASA 5510. I have configured Port 2 on the 526 for VLAN 2 (guest VLAN -10.1.250.2) - Port 1 is configured for Corporate access and management, it connected to the LAN switch and works fine. I have connected Port 2 directly to ethernet 0/3 on the ASA. On the ASA, I have created a subinterface and assigned it VLAN 2 (10.1.250.1). I have also configured DHCP on the ASA and enabled it on Ethernet 0/3.
Is this configuration supported? - a. I am unable to get a DHCP address when connecting to the guest VLAN and b. even when assigning myself a static IP address in the guest VLAN range, it am unable to ping the WLC or eth 0/3 on the ASA and not able to get out to the internet (do not even get the web authentication page). From eth 0/3 on the ASA, I am able to ping Port 2 of WLC526…
Please help!!
aghaznavi Tue, 06/02/2009 - 13:16
  • Silver, 250 points or more
Verify that your Ethernet adapter is configured to receive an IP address from a DHCP server on a Windows-based PC.
Trending Topics - Security & Network
