how to set HWIC-AP-AG to non-root with given SSID and NO security ?
May 26th, 2009
It seems I can't make an AP-AG installed on my router work as universal client with some given SSID (which by the way is working fine on a laptop with Ubuntu alongside the router set as same SSID with no security -is this what its called guest mode ?)
relevant commands following:
dot11 ssid whatever
authentication open
interface Dot11Radio0/1/0
description alternate uplink
ip address dhcp
ip nat outside
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
interface FastEthernet0/1
description IntraNet
ip address ...
ip nat inside
... when I set Dot11Radio0/1/0 to no shutdown the traffic activity LED on the C1841 goes crazy indefinetly, the radio shows channel locking, but it says it the remote AP is not responding ... given that my laptop can access and use this remote AP I presume I'm doing something wrong in the router configuration
system image is c1841-advsecurityk9-mz.124-22.T.bin
