Site2Site with port restrictions
I'm working on a site-to-site from my ASA5505 to a non-cisco firewall
I need to allow a specific IP on the other side to access my network using the following ports: 80, 443, 2980
this is what I came with:
name A.B.140.2 NONCISCO_Ext description CLIENTSIDE external IP
name A.B.3.69 NONCISCO_Int description CLIENTSIDE internal IP
name 192.168.X.Y MY_LAN
access-list inside_nat0_outside extended permit ip host 192.168.X.Y host A.B.3.69
access-list NONCISCO extended permit ip host 192.168.X.Y host A.B.3.69
access-list NONCISCO_NAT extended permit ip host 192.168.X.Y host A.B.3.69
static (inside,outside) 192.168.X.Y access-list NONCISCO_NAT
crypto ipsec transform-set CLIENTSIDE esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map0 20 set pfs
crypto dynamic-map outside_dyn_map0 20 set transform-set CLIENTSIDE
crypto map CLIENTSIDE_VPN 20 match address NONCISCO
crypto map CLIENTSIDE_VPN 20 set peer A.B.140.2
crypto map CLIENTSIDE_VPN 20 set transform-set CLIENTSIDE
crypto map CLIENTSIDE_VPN 65535 ipsec-isakmp dynamic outside_dyn_map0
crypto map CLIENTSIDE_VPN interface outside
tunnel-group A.B.140.2 type ipsec-l2l
tunnel-group A.B.140.2 ipsec-attributes
pre-shared-key ******
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
I have 2 problems:
1. group object
I've created a group-object that allow eq 80 \ eq 443 & eq 2980
how\where do I apply it?
when I tried the access-list I got a conflict message since those same port are being used on the external link for one of my apps
2. is there a better way to configure this VPN?
