VPN s2s tunnel after PAT and NAT on non-cisco
May 26th, 2009
I have cisco 1711. on LAN there is ZYXEL firewall. I have tried to establish s2s tunnel betwenn this LAN zyxel and other Zyxel on the other side with WAN.
interface Serial0
description Polaczenie do Internetu$FW_OUTSIDE$
bandwidth 2048
ip address 80.50.92.xxx
ip nat pool PAT prefix-length 29
ip nat inside source static 213.77.105.xxx extendable
ZYXEL is LAN and NATed to 213.77.105.xxx
my qestion is:
is there posibility to establish s2s tunnel with host that in LAN has NATed to WAN address as above?
ybtheneonet Wed, 05/27/2009 - 02:34
So you're saying that your configuration is :
Zyxel (LAN ) -> 1711 -> Zyxel (WAN ) and you want to establish a l2l VPN tunnel between the LAN and WAN Zyxel firewalls and you're NATting the LAN Zyxel firewall to a WAN address?
If yes, then your answer is : Yes you can do a VPN but using NAT-Traversal. It's a technology where the IKE ports of the initiator and the responder are changed from their default value of 500 to 4500 in order to support NAT devices working in-between the VPN. If your Zyxel firewall supports NAT-T then there's a good chance this will work
grzegorz.niecka Wed, 05/27/2009 - 03:20
thnx for Your kindly reply.
On Zyxel VPN configuration screen I can "thick" option "NAT Travelsal" (now it is unthicked) but no additional configuration options.
Shall I perform additional configuration on 1711 to support Nat-Travelsal on Zyxel?
ybtheneonet Wed, 05/27/2009 - 06:04
Yeah try checking that option on the Zyxel firewall. On the 1711 there are no configurations required, just do the usual NAT. See if that works
