Block an IP in the same Vlan
May 27th, 2009
Dear All,
How can i block a single IP with in a VLAN. this ip should not be able to access any other ips in the same vlan as well as other vlan in the network.
i have cisco WS-C3560G-48TS switch with me. please help me to do the same
Overall Rating: 3 (1 ratings)
arunsing Wed, 05/27/2009 - 02:16
I think you can create an inbound access-list and apply it to the vlan.
access-list 101 deny ip host any
access-list 101 permit ip any any
I am assumming that you are using the switch as an L3 switch
iyde Wed, 05/27/2009 - 02:40
  • Silver, 250 points or more
Try looking into the Private VLAN feature.
The ACL method mentioned will not block trafic within the same VLAN.
HTH.
mahmoodmkl Wed, 05/27/2009 - 02:43
  • Gold, 750 points or more
U need to use vlan-maps to achieve it.
Mahmood
cisco_lad2004 Wed, 05/27/2009 - 03:00
As Ingolf mentionned, you need PVLAN to tale care of L2 blocking combined with an ACL for L3 blocking.
Sam
