CAR fails to output if pdf selected
May 27th, 2009
I'm looking at what needs to be done to output to any other format than csv. If I select output to pdf, the system just hangs.
Is there a plugin I need to install.
Currently running CM 6.1(2)
Chris
Jaime Valencia Wed, 05/27/2009 - 06:11
  • Cisco Employee,
  • Hall of Fame,
    2011
Try restarting the CAR services and then give it a try
java
if this helps, please rate
daviddunaway Tue, 07/07/2009 - 10:43
I am having the same issue.
I have tried restarting said services, but the problem remains. No matter what report I try to run, if I select PDF as the output, IE crashes. It worked last week, nothing has changed...
