debugging and logging
May 27th, 2009
Hi all
when I run debugs on my router, say for each process, I notice that there is also a debugging option for logging level?
what are the differences here?
glen.grant Wed, 05/27/2009 - 03:43
If you want all the debugging messages put into the logg buffer then logging would have to be set to debugging , if you just want to watch the messages come across the console then logging debugging is not needed .
carl_townshend Wed, 05/27/2009 - 05:41
hi there
so, if I say do a debug spanning tree, and then type logging trap debugging, or logging monitor debugging, will i see this on there ?
