05-27-2009 03:37 AM - edited 03-06-2019 05:57 AM
Dear Freinds,
Stuck up with a scenerio where i have many IPs / IP pool configured in a single Vlan (for eg:- Vlan 10) or single broadcast domain. and i need/want that no IPs/IP Pool can communicate to any other Ips in Vlan 10. What need to be done to fulfill this.
05-27-2009 03:45 AM
Hi:
You can use the traditional method for isolating a vlan by using ACLs. You would apply an ACL to the layer 3 interface for vlan 10.
Alternatively, you can place the vlan in a VRF, which would isolate other VRFs from it.
Victor
05-27-2009 03:47 AM
Jimmy,
this is a job for private vlans, PVLANs will ensure hosts do not communicate together at Layer 2...this means you still need to have an ACL to take care of Layer 3 communication.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/pvlans.html
Sam
05-27-2009 04:31 AM
Sam:
I must have misunderstood. I thought he was trying to block inter-vlan communications, not inter-host (intra-vlan) within vlan 10.
