Auto Attendant Failure
sheerazkhatri
I am using CCM 4.1(3). I have 2 auto attendant console clients running cluster wide. Both were working fine but today one of the client is keep giving problem. While trying to run the client it says "connecting to server" and stays there forever while the other client is working fine.. I tried to uninstall and reinstall but didnt work.. Did device reassociation as well but didnt work... Any help please ?
Sheeraz
Jaime Valencia
Try restarting the TCD service
java
if this helps, please rate
java
Jaime Valencia
java
java
