the way of control parameter of dampening at specific neighbor
May 27th, 2009
I would like to adjust dampening rule in bgp at specific neighbor.. Is it possible?
for example. Neighbor A and Neighbor established with BGP. but Neighbor A was so frequently routeing update to Neighbor B, So Neighbor B give to Neighbor A Panelty, so Neighbor A can't update network to Neighbor B..
So I don't want to give Neighbor A panelty.Is it possible? if possible, show me the configuration and verification command..
thank you
cisco_lad2004 Wed, 05/27/2009 - 05:45
Router(config-router-af)# bgp dampening route-map TEST
With route map, you have few options that will help to dampen the desired neighbour but not as straighforward command.
You can match on prefixes or source etc..
