New Cisco Switch Implementation
May 27th, 2009
Just purchased a SGE2010 48 port switch and need to configure it and install into my network. Bought this switch so I could remove a very old Dell Power Connect switch that feeds my 9 servers, and computers, printers, etc and uplinks to a 3com baseline switch 2250 plus which feeds the remaining printers and computers.
I would like to possibly remove both old switches and implement this sge2010 so that all servers, computers, printers, etc are on 1 switch, implement VLAN's? Connect servers with their Dual GB nics?
I am open to any suggestions and new to setting up Cisco switches.
davidsudjiman Fri, 05/29/2009 - 15:13
If you new, particularly to Cisco Switches, you might need to check the configuration document on cisco website http://www.cisco.com/en/US/products/ps9984/index.html
Assuming all of those servers, computer and printers are on same subnet, you can just plug them all into the switch port 1-48 and it will work as all of those will be assigned to VLAN1 and the port will act as a switchport.
You might also need to configure the port as follow (quick and dirty)
int range f0/1 - 48
switchport mode access
switchport access vlan 1
switchport nonegotiate
spanning-tree portfast
exit
