ASA5505 2nd Site-to-Site config
I have a working Site-to-Site on my ASA5505
I have to configure a 2nd VPN, identical to teh existing VPN (obviously using different IPs & key)
this is the existing VPN config:
access-list SITE1_FIX extended permit ip host 192.168.x.y host A.B.C.D
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set SITE1 esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set reverse-route
crypto dynamic-map outside_dyn_map0 20 set pfs
crypto dynamic-map outside_dyn_map0 20 set transform-set SITE1
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map SITE1VPN 20 match address SITE1_FIX
crypto map SITE1VPN 20 set peer x.y.176.251
crypto map SITE1VPN 20 set transform-set SITE1
crypto map SITE1VPN 65535 ipsec-isakmp dynamic outside_dyn_map0
crypto map SITE1VPN interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group x.y.176.251 type ipsec-l2l
tunnel-group x.y.176.251 ipsec-attributes
pre-shared-key *
for the new VPN for SITE2, can I use the same crypto dynamic-map outside_dyn_map 20 & crypto map SITE1VPN 20 ???
anything to pay extra attention to while configuring it?
Richard Burts Wed, 05/27/2009 - 13:55
Ofir
To create a second site to site VPN you will need to configure:
- an access list for them similar to access-list SITE1_FIX but with a different name and address unique to the new site.
- a new instance within crypto map SITE1VPN - perhaps SITE1VPN 30 (you can not use SITE1VPN 20 over again).
- a tunnel-group for the new connection.
Depending on whether they will use the same transform set and isakmp policy you may need to configure new ones of these also.
Rick
