AIR-1252 Antennas required?
Answered Question
May 27th, 2009
Just purchased 2 AIR-LAP-1252AG-A-KP APS. I notice it has external Antenna Connectors. I have loked in the Doc but can;t find the info I am looking for. I want to use them inside a gym and was wondering if they will work without external antennas.
Mike
Correct Answer by Leo Laohoo about 7 years 12 months ago
Hi Mike,
Antenna Product Portfolio for Cisco Aironet 1250 Series Access Points
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/at_a_glance_c45-513837.pdf
Avoid running the AP's without any antennaes or you might permanently damage the transceiver.
Hope this helps.
Correct Answer by Rob Huffman about 7 years 12 months ago
Hi Mike,
The 1252 does not have "built-in" Antenna/Antennas options, so external Antennas are required;
Supported Antennas are listed in this doc;
http://www.cisco.com/en/US/docs/wireless/access_point/1250/installation/guide/125h_c1.html
Have a look at this good thread which includes some good insight on Antenna options, from Dennis, who is very knowledgable about 11n;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddfd891
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Wed, 05/27/2009 - 08:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Mike,
Hope this helps!
Rob
Correct Answer
Leo Laohoo Wed, 05/27/2009 - 16:46
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Hi Mike,
Hope this helps.
michael.m.williams Thu, 05/28/2009 - 05:27
SUper,
Thanks so much. Looking at the different radiation patterns really helps when figuring out which antenna I need.
Thank you.
Mike
Leo Laohoo Thu, 05/28/2009 - 14:53
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the ratings, Mike.
