paolo bevilacqua Wed, 05/27/2009 - 07:39
  • Hall of Fame,
    Founding Member
You cannot do that if you don't have firmware files and a TFTP server, without these the telephone will become a brick once you enter the reset sequence.
sivaprakasam81 Wed, 05/27/2009 - 07:53
Thank you for the information. How can i take backup of the image (formware). I can use tftpd32.
Thank you
paolo bevilacqua Wed, 05/27/2009 - 07:56
  • Hall of Fame,
    Founding Member
There is no way to backup images from a cisco phone.
Please remember to rate useful posts with the scrollbox below.
sivaprakasam81 Wed, 05/27/2009 - 08:10
How do I get the firmware for the IP Phone? Is there any way, i can check the funcitionality of the IP phone without going through all these?
paolo bevilacqua Wed, 05/27/2009 - 08:13
  • Hall of Fame,
    Founding Member
You need a support contract to download firmware from CCO.
Sorry, there is no easy way.
sivaprakasam81 Wed, 05/27/2009 - 08:18
I am not sure about the support contract on this product. What is going to happen by uploading the firmware? Can I just connect it to the Appropriate router/Switch and use the existing firmware verion.
Can you please name the router/switch is most compatible with IP phone 7960G
paolo bevilacqua Wed, 05/27/2009 - 08:24
  • Hall of Fame,
    Founding Member
Be reassured that you don't have a support contract currently.
If you connect to a router and configure CME, you should be able to use current FW and do calls.
Any recent router can be used, ISR, 26xx, 36xx, etc.
sivaprakasam81 Wed, 05/27/2009 - 08:49
Thank you very much. Can I have some link to get resource for configuring CME on 26xx or 36xx router?
sivaprakasam81 Thu, 05/28/2009 - 05:17
Thank you So much for the support. Can I use 35xx Switch or 800 series router for CME configuration?
