Cisco CSS 11503 TACACS
May 27th, 2009
I have a strange question with regards to the config applied to the CSS. I have applied the config and all authentication works without fail and I can test access in the event of the TACACS server unavailable.
The silly question is when you enable TACACS the hostname of the CSS goes to its default and even if you change it back to the required via the command "prompt CSS1" it takes the command and shows that hostname for that session. As soon as you log out and go back in the CSS defaults back to the olde CSS11503. I am at a loss how to overcome this and its annoying as there are many CSS's in the business that needs the TACACS enabled.
The version is sg0750103
Any help would be much appreciated.
Kind Regards
Steven
sadcock123 Wed, 05/27/2009 - 07:02
Sorry to waste peoples time.
Just tried the "prompt CSS01" then save_profile and this works.
Kind Regards
Steven
