Problem TFTP in pix
John Blakley Wed, 05/27/2009 - 09:44
  • Purple, 4500 points or more
Jorge,
What are you typing to get this error message? You didn't give us much to go on :)
HTH,
John
jorgesilvaf Wed, 05/27/2009 - 11:18
Hi j.blakley
this that i typing :
wr net jorgef:63.txt
Building configuration...
TFTP write '63.txt' at jorgef on interface 1
tftp: out of states
Can't open tftp client
[FAILED]
Usage: write erase|floppy|mem|terminal|standby
write net []:
thanks
John Blakley Wed, 05/27/2009 - 11:23
Jorge,
You need to specify the ip address of your tftp server. If you're running a tftp server on your laptop, for instance, and your laptop's ip address is 192.168.1.50, then your command would be:
wr net 192.168.1.50:63.txt
If you don't have a tftp server, I recommend tftpd32.
HTH,
John
jorgesilvaf Wed, 05/27/2009 - 11:52
hi
same error :
wr net 10.198.50.16:63.txt
tftp: out of states
[FAILED]
write net []:
jorge
jorgesilvaf Wed, 05/27/2009 - 11:57
yes , i have a solarwinds in my pc . Others pix and routers i'm able to copy the configurations .
thanks a lot
jorge
John Blakley Wed, 05/27/2009 - 12:14
Hmmm....try this (forgive the syntax if incorrect)
PIX(config)# tftp-server inside 192.168.1.1 63.txt
PIX# wr net
jorgesilvaf Wed, 05/27/2009 - 12:28
(config)# tftp-server spcbr 10.198.10.16 63.txt
(config)# wr net
TFTP write '63.txt' at 10.198.10.16 on interface 0
tftp: could not open udp/0/12345/10.198.10.16/69
[FAILED]
write net []:
John Blakley Wed, 05/27/2009 - 12:32
Jorge,
tftp: out of states
[FAILED]
And in the last one:
Is your tftp server on the outside of the pix or the inside of the pix? Do you have an acl on the interface that you're going out on?
John Blakley Wed, 05/27/2009 - 12:35
If you have an acl, try adding a permit statement for udp/69.
jorgesilvaf Fri, 05/29/2009 - 05:47
Hi guy , the problem is the pix , when try reload , appear the follow error :
"Currently writing image. Cannot reload"
Thanks a lot
Jorge
