05-27-2009 07:58 AM - edited 03-18-2019 11:06 PM
I have two CER servers configured as primary / secondary in a group. They are showing 100 user license each. I am trying to upload the 300 more user license , the file get uploaded and it says that license file validated and sucessfully uploaded.
But the user license counts still says 100.
Any thoughts ??
05-27-2009 08:16 AM
can you run the command below and post the screen output?
run sql select * from cerserver
Michael
05-27-2009 09:14 AM
admin:run sql select *
A syntax error has occurred.
admin:
admin:run sql ?
Syntax:
run sql sql_statement
sql_statement mandatory the sql command to run
admin:run sql
05-27-2009 09:46 AM
"run sql select * from cerserver"
type each letter between the quotes
05-27-2009 10:11 AM
admin:"run sql select *"
Executed command unsuccessfully
No valid command entered
admin:run sql select * from cerserver
pkid serverid hostaddress priority tracepackagelist debugpackagelist servername userlicensecount
5c7c78f5-9f57-433c-bb7a-cd6970a2d209 Publisher PVDCER01 0 CER_TELEPHONY;CER_PHONETRACKINGENGINE;CER_REMOTEUPDATE;CER_DATABASE;CER_CALLENGINE;CER_ONSITEALERT;CER_CLUSTER;CER_SYSADMIN;CER_GROUP;CER_AGGREGATOR CER_TELEPHONY;CER_PHONETRACKINGENGINE;CER_REMOTEUPDATE;CER_DATABASE;CER_CALLENGINE;CER_ONSITEALERT;CER_CLUSTER;CER_SYSADMIN;CER_GROUP;CER_AGGREGATOR PVDCER01 100
7cb9fcbf-67ff-4dc2-ad16-407363fda52d Subscriber PVDCER02 1 PVDCER02 0
admin:
