05-27-2009 08:12 AM - edited 03-06-2019 05:57 AM
I have DHCP snooping turned on and everything is running fine. I'm now getting ready to move toward turning on verify source, however I want to make sure all devices are set with DHCP or have a static map.
Is there an easy way to do this?
Is there a way to turn on verify source to log only what it would block? Kind of like a test mode.
Thank you
05-27-2009 11:02 PM
Hello Jeff,
No this is not possible
see
About preliminary tests you shoud compare the output of CAM table (sh mac-address-table )
the output of DHCP snooping related information using
show ip dhcp snooping database [detail]
for ports not dynamically learned by DHCP snooping you need to verify if a manual binding exists.
Hope to help
Giuseppe
06-02-2009 05:01 AM
I'm also in the same position above. I have configured DHCP snooping etc all working ok.
I have IP phones being assigned addresses from the Layer 3 switch, I have clients being assign IP's from a local DHCP server.
I have configure a static binding for my DHCP server, but as soon as I enter the interface command "ip verify source port-secuirty", any new client that is not already in the DHCP snooping database fails to get an IP addresses. The IP phones are unaffected and carry on working normally -
Any Ideas ?
Paddy
