Need router recommendation
Answered Question
May 27th, 2009
I am working with a small parochial school and their network of about 50 PCs.
They currently have a Cisco 1720 router that their ISP manages and they have used a Linksys BEFSR41 router for DHCP and NAT.
I am investigating a replacement router as the Linksys seems to get hung up frequently affecting their Internet accesss.
Can you recommend a Cisco router to perform these functions for us?
thanks,
Tim T.
Correct Answer by Leo Laohoo about 7 years 11 months ago
Hi Tim,
I agree with Tom. If you want a Cisco router that you can do CLI or HTML configuration, then 850/870 series Integrated Services Router (ISR) is a viable option.
Data Sheet Cisco 850 Series Integrated Services Routers
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6195/product_data_sheet0900aecd8028a9a9.html
Data Sheet Cisco 870 Series Integrated Services Routers for Small Offices
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/product_data_sheet0900aecd8028a976.html
Hope this helps.
Overall Rating: 5 (1 ratings)
Brandon Buffin Wed, 05/27/2009 - 12:15
  • Purple, 4500 points or more
Tim,
The 1720 could certainly handle these functions. One option would be to have the ISP setup the existing router for you. If you're looking to buy another router that you can manager, take a look at the 1800 series. The 1811 would likely work well for your scenario.
http://www.cisco.com/en/US/products/ps5853/index.html
Hope this helps.
Brandon
ttraver Wed, 05/27/2009 - 12:29
I approached the ISP about modifying the router and they do not want to support that for us. I can understand as they have many education accounts and cannot do customization at that level.
That router is several hundred dollars. I did not mention that our budget is limited. Can you recommend something cheaper?
Tim
ttraver Wed, 05/27/2009 - 12:49
Thank you for your patience. This is relatively new to me.
What do you think of the Cisco RVS4000 router? Too light weight? I just did a search sort on price, low to high.
Tim
Brandon Buffin Wed, 05/27/2009 - 12:55
This is a Linksys router and is definitely on the low end. It does perform the functions that you need. However, I would lean towards something more robust for an office of 50 people.
Brandon
Correct Answer
Leo Laohoo Wed, 05/27/2009 - 16:13
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Tim,
Hope this helps.
pompeychimes Wed, 05/27/2009 - 21:04
  • Bronze, 100 points or more
Buy a used 17xx or 26xx. They are real cheap and you wont be out too much if they fail.
Leo Laohoo Thu, 05/28/2009 - 14:54
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the rating Tim.
