asa 5510 nat
May 27th, 2009
Hi, My asa device has 3 external ip address. On of the addresses is used for static pat to a host on the inside network. If a inside host tries to access the external resource not using the asa as the default gateway it works.If the inside client uses the asa as the default gateway it does not work.
Any suggestions appreciated.
jason
bob.bartlett Thu, 06/18/2009 - 19:05
you need to have a nat and global configuration to tell the ASA to nat the internal resources and what address to nat them to
nat (inside) 1 0 0
global (outside) 1 xx.xx.xx.xx
Bob
