Warning message
Joe Clarke Wed, 05/27/2009 - 12:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Not fully, no. We are adding HA support via Veritas clustering in LMS 3.2. LMS 3.2 is due out early this summer.
LMS 3.1 will allow you to centralize the Device Credential Repository and user authentication data by enabling DCR and SSO master/slave respectively. This PDF (for LMS 3.0, though many concepts still apply) will help you understand how you can make LMS work in a large-scale environment today:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/ps7196/prod_white_paper0900aecd80695cad.pdf
darwintobardelgado Thu, 05/28/2009 - 06:27
Jclarke,
I have other question for you. Is possible to integrate Cisco works LMS 3.1 with Netcool?. If it does, please, may you send information about this?.
Best regards,
DT.
Joe Clarke Thu, 05/28/2009 - 08:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is no tight integration between LMS and Netcool. You can, however, forward traps from DFM to Netcool. Trap forwarding can be configured under DFM > Configuration > Other Configurations.
