VM port DN numbering
May 27th, 2009
My phones have 6 digit extensions. Is it an acceptable practice to have the VM pilot and vm ports with 4 digit extensions? Vm is working, yet I notice from the call viewer that the dialed number shows up as ??3000. thanks
iptuser55 Fri, 05/29/2009 - 02:26
  • Silver, 250 points or more
It doesn`t matter what DN you have for the VM- don`t forget you may have a cluster supporting differnt numbering schemes 3 digits, 4 digits etc , as long as the VM ports work and you do not have any number,partition clashes then any number is technicaly ok
