Route-Map + NAT + 2 ISP
May 27th, 2009
I'm currently testing failover between 2 ISP using the one Cisco 3800.
The problem is once the primary link goes down, the backup is active using floating static but Internet.
Looking at the NAT trans and there is no trans on the backup link IP Address pool.
The challengin part of this project is that we only have 2 Ethernet Interface on the 3800 and both are already in use for WAN and LAN.
Below is my config:
interface GigabitEthernet0/0
description LINK TO PRIMARY LINK
ip policy route-map NAT-to-ISP1
ip address x.x.x.x 255.255.255.252
interface GigabitEthernet0/1
description LINK TO SWITCH STACK - 3560
no ip address
interface GigabitEthernet0/1.500
description LINK TO BACKUP LINK
ip policy route-map NAT-to-ISP2
ip address y.y.y.y 255.255.255.252
ip route 0.0.0.0 0.0.0.0 x.x.x.x name PRIMARY
ip route 0.0.0.0 0.0.0.0 y.y.y.y 50 name BACKUP
ip nat inside source route-map NAT-to-ISP1 interface GigabitEthernet0/0 overload
ip nat inside source route-map NAT-to-ISP2 interface GigabitEthernet0/1.500 overload
route-map NAT-to-ISP1 permit 10
match ip address NAT_ACL
match interface GigabitEthernet0/0
route-map NAT-to-ISP2 permit 10
match interface GigabitEthernet0/1.500
As you can see, the backup link is connected to our internal switch stack on gig0/1 and I have created a sub-interface assign access VLAN 500 on the switch port. We are not using dynamic routing on both WANS.
Once the primary link goes down, I can see the floating static adding the backup as the default gateway using AD.
Have I miss anything? I know the problem is NATing.
paolo bevilacqua Wed, 05/27/2009 - 17:08
  • Hall of Fame,
    Founding Member
You are missing ip nat inside and ip nat outside commands for the interfaces, and the encapsulation dot1q for the subinterface.
Peter Valdes Wed, 05/27/2009 - 17:59
Sorry, the config is applied on the router. I just forgot to type it in here.
Config:
ip dhcp pool 100
network 192.168.101.0 255.255.255.0
default-router 192.168.101.1
dns-server a.a.a.a b.b.b.b
lease 7
ip nat outside
no ip address
interface GigabitEthernet0/1.100
description LAN PC
encapsulation dot1Q 100
ip address 192.168.101.1 255.255.255.0
ip nat inside
encapsulation dot1Q 500
ip nat outside
paolo bevilacqua Wed, 05/27/2009 - 18:12
  • Hall of Fame,
    Founding Member
You need to have g0/0 to be down for the new route to install and translations to delete. Does this happens ?
