Unity Error
May 27th, 2009
Im doing a CCA Lab (UC500-CCA-First-Look-v1-Lab4), but there's a section in a lab the requiere to use the unity express Web config, but when I try to click on:
I get the following error:
Error: Unable to login as administrator to the Cisco CallManagerExpress at site 'local'.
Details: CME login failed
Thanks in advance.
weeksgroove Thu, 05/28/2009 - 06:37
That isn't the config that is attached.
If you have not changed your IP addreses.  You should connect to  Once in there, you may have to run the CME/CUE setip wizard to make sure the CUE Admin and CME admin passwords are synd.
anbatist Thu, 05/28/2009 - 06:50
Now is the correct config. The Unity doens't allow me to run the initial wizard again, what can I do in this case?
Marcos Hernandez Thu, 05/28/2009 - 07:10
The CUE Setup Wizard is a one shot kind of deal. You would have to bring the system to factory defaults for it to show up again. Did you try the command that I suggested?
anbatist Thu, 05/28/2009 - 07:26
Hi Marcos,
With a lot of response (that is not a bad thing) I don't pay attetion to your response (excuseme man). Now I issue the command that you suggest (ip http path flash:/gui) and all my problems (excluding financial)
  were resolve.
thanks for your help.
