LMS 3.0 Discovery problem
May 27th, 2009
Dear All,
I am using LMS 3.0, my problem is when scheduled discovery started, it does not finish and continuously running when I click device discovery page to see the status I got this error(snap shot attached). first time I resolve this issue by restarting Daemon manager, but now it becomes a daily issue. Is there any patch available to resolve this issue permanently.
Joe Clarke Thu, 05/28/2009 - 08:33
It looks like Discovery has crashed. Do this. Run the following command on the server:
pdterm CSDiscovery
Then, delete the NMSROOT/conf/csdiscovery/DiscoveryStatusObj. then try re-running Discovery, and see if it completes.
hashmatpaki Thu, 05/28/2009 - 21:25
It seems that there is no such file.
# pwd
/opt/CSCOpx/conf/csdiscovery
# ls -l
total 590
-rw-r----- 1 casuser casusers 13136 May 27 13:46 CSDiscovery-config.xml
-rw-r----- 1 casuser casusers 773 Aug 24 2007 CSDiscovery.mf
-rw-r----- 1 casuser casusers 30 May 28 07:04 SNMPv3CacheParam.properties
-rwxr-x--- 1 casuser casusers 21760 Nov 1 2007 SharedDiscoveryAUS.zip
-rwxr-x--- 1 casuser casusers 20377 Nov 1 2007 SharedDiscoveryCluster.zip
-rwxr-x--- 1 casuser casusers 129069 Nov 1 2007 SharedDiscoveryGeneral.zip
-rwxr-x--- 1 casuser casusers 85345 Nov 1 2007 SharedDiscoveryIGX.zip
-rw-r----- 1 casuser casusers 1178 Oct 29 2007 csdiscovery-ctm-log4j.properties
-rw-r----- 1 casuser casusers 1625 Oct 24 2007 ngd-log4j.properties
-rwxr-x--- 1 casuser casusers 2675 Sep 19 2007 removeCSDiscovery.pl
-rw-r----- 1 casuser casusers 10472 May 27 13:46 system-config.xml
# ls
CSDiscovery-config.xml SharedDiscoveryCluster.zip ngd-log4j.properties
CSDiscovery.mf SharedDiscoveryGeneral.zip removeCSDiscovery.pl
SNMPv3CacheParam.properties SharedDiscoveryIGX.zip
system-config.xml
SharedDiscoveryAUS.zip csdiscovery-ctm-log4j.properties
