05-27-2009 10:32 PM - edited 03-18-2019 11:07 PM
customer is going to add a second unity server to the the Exchange, this is part of a migrating from the old unity server.
When they install the new unity server adding the service accounts and run the schema extension - will this mess up the current Unity 4.0.4 integration?...the new unity will be 5.X both connecting to the same Exchange.
Any advise and recommendation would be much appreciated!
Mattias
05-28-2009 03:11 AM
You can use the accounts you already have, schema is backward compatible.
You shouldn't have nay issues.
java
if this helps, please rate
05-28-2009 05:56 AM
Just an added tid bit here. ADSchema only adds attributes and will not delete any existing ones. That is why this is compatible.
Tray
