Jonathan Schulenberg Thu, 05/28/2009 - 07:05
  • Cisco Designated VIP,
    2017 IP Telephony
Are these ACD calls or a direct call to the extension? If it's an ACD call and the agent is really Not Ready, open a TAC case.
Not Ready does not prevent people from calling the DN directly. It only stops the ACD subsystem from considering that agent for a call.
javed.hashmi Thu, 05/28/2009 - 21:23
Well its an ACD call and not direct call .Opening a TAC case well right now i cant open a TAC case thats why asked for help on this forum .
david.macias Thu, 05/28/2009 - 23:45
  • Blue, 1500 points or more
I've never seen something like this, not saying it's not possible, can you double check the agent is login in to the right phone?
david
kre8or2007 Wed, 06/03/2009 - 11:11
I would also make sure the agent didn't close out the application and without logging out, I have this trouble alot with our system
Christopher Nagel Mon, 06/08/2009 - 13:07
Some installations set Agent State to 6 which is Work Ready, when typically the call center personnel are used to having Agent State = 5, Work Not Ready. Perhaps this is where the confusion lies?
Chris
kre8or2007 Mon, 06/08/2009 - 13:25
Also double check and make sure some other agent isn't logged in to this agent's extension. I've had that happen on our system and had to track this down in the real time reporting to see what agent is logged into what extension.
