bba-group pppoe global command
May 27th, 2009
Hello
I am using Cisco IOS Software, 7200 Software (C7200P-K91P-M), Version 12.2(31)SB14, RELEASE SOFTWARE (fc5)in my 7206 vxr router which I am configuring as an ISG.
The command " bba-group pppoe global " is not taken by the router , says unknown command. Any suggestion for why it is not taking or is there any alternate command for it ?
Any suggestions are welcome.
Abhishek
Edison Ortiz Fri, 05/29/2009 - 12:45
Try this image instead c7200p-spservicesk9-mz.124-15.T9.bin
Edit: After further research, that image won't support ISG features.
With your current IOS, can you enable 'vpdn' and see if the command becomes available.
Type vpdn enable
http://www.cisco.com/en/US/docs/ios/vpdn/command/reference/vpd_v1.html#wp1011839
I've seen cases that without this command, any PPPoE related features aren't available.
HTH,
__
Edison.
