May 28th, 2009
i ' ve a problem.
There 2 LAN , Site 1 and Site 2
Site 1 and site 2 have a number 1 cisco 3550 l3 and number 2 cisco 2950
cisco 3550 l3 of site 1 is connect to a cisco 3550 le of site 2 with a routed port.
I must realize a Remote SPAN from site 2 to site 1.
i must create in all two site a new vlan.
in the site 2 there is a pc that i want to sniffing.
I create a remote SPAN port with source the port of pc that i want to snif and destination a vlan.
in the other site i must do to the same with a sorce of new vlan and the destination the fastethernet where i want to connect my pc for to snif.
how can i do for to CONNECT THE new vlan (for example vlan id 10) of two site?
I THINK a TUNNEL GRE from 2 site but i down't know if is a good solution.
WHAT IS a mode of to connect a vlan of two sites connect to level3 ?
thanks for your help
fcostalunga Fri, 05/29/2009 - 00:22
i've read the explain but i don't find the solution a my problem.
I must connect a singe vlan of 2 sites.
the vlan id is the number 50.
i must create a remote span using the vlan 50 and with a tunnet i hope that pass all traffic.
I don't see an example of this situation.
The 2 sites in connected in ospf with a fiber , and gigaport set in router port.
Giuseppe Larosa Fri, 05/29/2009 - 02:16
Hello Francesco,
you need to connect a L2 trunk port of switchA site A to an interface on RA.
the trunk has to carry vlan50 in the list of allowed vlans.
RA has an 802.1Q subinterface like
int gi0/0.50
encapsulation dot1q 50
! xconnect commands here
on the other side you need to do the same:
switchB connect with trunk to RB
and RB has to be configured in similar way.
note: on both sides the subinterface has no ip address.
The L2TPv3 tunnel carries frames with tag 50 to the other router.
the scenario should be:
SwitchA--RA --- IP WAN --- RB--SwitchB
RA |<------------------->|RB
Hope to help
