H323 Gateway - POTS Dial-peers
uccertltd
Hi There, this issue is causing me much frustration. We are running CUCM 6.1 and a 3845 ISR running advipsvcs 124-15.T8 IOS. Basically, outbound calls are not matching the specific dialpeers that I have configured on the H323 Gateway. We also have a GSM gateway on port 0/2/1 which should be routing mobile calls 69........
We have the following Route Patterns, all set to Discard Digits <none>. The route list is also configured with Discard Digits <none>:
0.14XXX
0.69XXXXXXXX
0.2XXXXXXXXX
0.80XXXXXXXX
0.00!
0.118XX
0.901!
0.11XXX
166
199
100
We have the following Dial-peers configured, but all outbound calls are matching dial-peer 2000:
dial-peer voice 2001 voip
preference 1
destination-pattern 2...
voice-class codec 1
voice-class h323 1
session target ipv4:10.129.20.3
fax rate 7200 bytes 48
fax nsf 000000
fax protocol pass-through g711ulaw
no vad
dial-peer voice 2002 voip
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:10.129.16.34
fax nsf 000000
no vad
dial-peer voice 100 pots
tone ringback alert-no-PI
description **Police**
destination-pattern 100
progress_ind setup enable 3
progress_ind progress enable 8
incoming called-number .
direct-inward-dial
port 0/2/0:15
forward-digits all
dial-peer voice 199 pots
description **Fire Brigade**
destination-pattern 199
port 0/2/0:15
forward-digits all
dial-peer voice 166 pots
description **First Aid**
destination-pattern 166
port 0/2/0:15
forward-digits all
dial-peer voice 6969 pots
description **Mobile Calls**
preference 1
destination-pattern 0.69........
direct-inward-dial
port 0/2/1:15
dial-peer voice 2004 pots
description **Intl**
preference 1
destination-pattern 0.00T
direct-inward-dial
port 0/2/0:15
dial-peer voice 2005 pots
description **Greece PSTN**
preference 1
destination-pattern 0.2.........
direct-inward-dial
port 0/2/0:15
dial-peer voice 2006 pots
description **Freephone**
preference 1
destination-pattern 0.8.........
direct-inward-dial
port 0/2/0:15
dial-peer voice 2000 pots
preference 2
destination-pattern 0.T
direct-inward-dial
port 0/2/0:15
dial-peer voice 2007 pots
description **Dir Svcs**
preference 1
destination-pattern 0.1....
direct-inward-dial
port 0/2/0:15
uccertltd
Not to worry folks, resolved it after stepping back and looking at the config again...
on the pots dial-peer voice 69 I changed the destination-patter to 069........ and then did forward-digits 10. Works a treat.
uccertltd
