No changes applied on CCM 5.1.2
goranpilat
Level 3
Level 3
I have a problem on CCM 5.1.2. I can do the administration via web gui but no changes are really applied. E.g. I change DN on the phone, reset the phone everything looks fine on CCM but phone stays with the old DN. I delete the phone , and it is gone on CCM, but the phone is still perfectly usable. It might have something to do with DB and the fact that yesterday I had PUB's disk on 100%. Solved by TAC with root password and deleting unnecessary files. After it it seemed it was ok, but today I realised this new-old error.
Any ideas?
regards
Goran Pilat
htluo
Level 9
Level 9
This is called "change notification" issue. You may try to restart Database Layer Monitor. See if that fixed the problem.
For details, see http://htluo.blogspot.com/2009/03/change-notification.html
Michael
