SRST vs CM - loss of features
Answered Question
May 28th, 2009
Hi all,
When I configure SRSRT I understand that it is an exceptional situation and therefore when a phone looses connectivity with CM and falls into SRST mode, it also looses a big part of its configuration. That is, CSS, hunt groups, pickup groups and so on... keeping just basic call, call transfer and fwd, hold.
However, customer wants to keep all functionalities... But when phones are not registered they don't appear in the config, so I don't see how to apply corlists and all other things.
Should I configure manually all phones in order to apply the rest of features? Or it is not possible at all?
I couldn't find any documentation saying that I can or can't achieve that...
Any help would be highly appreciated.
Best regards,
Carmen
Correct Answer by Rob Huffman about 7 years 8 months ago
Hi Carmen,
Java is most correct here (+5 points buddy!)
There are two flavors of SRST (as shown below) and the one that you require is commonly referred to as Cisco Unified CME in SRST Fallback Mode. Here is the feature comparison;
SRST Fallback
This feature enables routers to provide call-handling support for Cisco Unified IP phones if they lose connection to remote primary, secondary, or tertiary Cisco Unified Communications Manager installations or if the WAN connection is down. When Cisco Unified SRST functionality is provided by Cisco Unified CME, provisioning of phones is automatic and most Cisco Unified CME features are available to the phones during periods of fallback, including hunt-groups, call park and access to Cisco Unity voice messaging services using SCCP protocol. The benefit is that Cisco Unified Communications Manager users will gain access to more features during fallback ****without any additional licensing costs.
Comparison of Cisco Unified SRST and
• First supported with Cisco Unified CME 4.0: Cisco IOS Software 12.4(9)T
• IP phones re-home to Cisco Unified CME if Cisco Unified Communications Manager fails. CME in SRST allows IP phones to access some advanced Cisco Unified CME telephony features not supported in traditional SRST
• Support for up to 240 phones
• No support for Cisco VG248 48-Port Analog Phone Gateway registration during fallback
• Lack of support for alias command
• Support for Cisco Unity® unified messaging at remote sites (Distributed Exchange or Domino)
• Support for features such as Pickup Groups, Hunt Groups, Basic Automatic Call Distributor (BACD), Call Park, softkey templates, and paging
• Support for Cisco IP Communicator 2.0 with Cisco Unified Video Advantage 2.0 on same computer
• No support for secure voice in SRST mode
• More complex configuration required
• Support for digital signal processor (DSP)-based hardware conferencing
• E-911 support with per-phone emergency response location (ERL) assignment for IP phones (Cisco Unified CME 4.1 only)
Cisco Unified SRST
• Supported since Cisco Unified SRST 2.0 with Cisco IOS Software 12.2(8)T5
• IP phones re-home to SRST router if Cisco Unified Communications Manager fails. SRST allows IP phones to have basic telephony features
• Support for up to 720 phones
• Support for Cisco VG248 registration during fallback
• Support for alias command
• Lack of support for features such as Pickup Groups, Hunt Groups, Call Park, and BACD
• No support for Cisco IP Communicator 2.0 with Cisco Unified Video Advantage 2.0
• Support for secure voice during SRST fallback
• Simple, one-time configuration for SRST fallback service
• No per-phone emergency response location (ERL) assignment for SCCP Phones (E911 is a new feature supported in SRST 4.1)
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps2169/prod_qas0900aecd8028d113.html
Hope this helps!
Rob
Correct Answer by Jaime Valencia about 7 years 8 months ago
What you need then is CME-as-SRST to support more features
java
if this helps, please rate
Overall Rating: 5 (3 ratings)
Correct Answer
Jaime Valencia Thu, 05/28/2009 - 03:56
java
Correct Answer
Rob Huffman Thu, 05/28/2009 - 04:59
Hi Carmen,
SRST Fallback
Cisco Unified SRST
Hope this helps!
Rob
mcibanez Thu, 05/28/2009 - 07:18
Many thanks for your help and your quick responses, guys.
Best regards,
Carmen
Rob Huffman Thu, 05/28/2009 - 08:33
Hi Carmen,
You are most welcome! Glad to be of some small help here.
Cheers!
Rob
