FLEXLINKS HELP
May 28th, 2009
Hello all,
Does flexlinks only work when physical link goes down or how?
I have two switches with two redundant links between them. The redundant link goes through radio.
My question is that, will Flexlink detect interference on the primary link and switch over to the back up?
thanks for your help.
Giuseppe Larosa Sat, 05/30/2009 - 13:12
  • Hall of Fame,
    Founding Member
Hello Joseph,
if both links are radio links this means there are boxes that have an ethernet port and a radio link : when radio has troubles the port is still up.
No STP BPDUs are exchanged on flexlinks so there is no way to guess the radio link is not working
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swflink.html
Hope to help
Giuseppe
jkofosu Mon, 06/01/2009 - 01:08
Dear Giuseppe,
Thanks for the info. Is there any layer 2 technology that can track a primary interface and then do an automatic failover?
Giuseppe Larosa Mon, 06/01/2009 - 02:13
  • Hall of Fame,
    Founding Member
Hello Joseph,
the only L2 tech you can use is STP, for doing so you need to configure the links without flexlinks option.
By adjusting STP costs or other parameters you can have the primary link you want.
Other possible options are present but ar layer3 and may be not available on your switches like reliable static routing
I would try with STP.
Hope to help
Giuseppe
jkofosu Mon, 06/01/2009 - 03:00
I am currently running the stp but I was thinking I could improve on my link with flexlinks.
Thanks alot for all your help.
