Changing the hostname of a CRS 5.02 server
May 28th, 2009
  • Silver, 250 points or more
I've searched the forum and saw the replies. But.. my SQL Server is working just fine after the change, I performed the procedure to change the name SQL DB wise but I'm having some other difficulties:
The serviceability tool still shows the old hostname.. so, where does it get that information from so that I can change it?
Also, I reconfigured the AXL host to another machine and now the login tells me the axl server hasn't been found. Which is a load of *%& because I know it works just fine (I normally write software and I know axl works just fine on that box).. so how do I trace that if I cannot access the trace configuration on the server?
